>60% spy-peers connected to freshly setup node
I recently set up two new nodes and right after IBD, a bunch of spy nodes started connecting to them. At some point over >60% of my peers were spies.
I found it surprising how aggressive the spies are.
Some of the peers:
id ip user agent tag connection type network transport tx relay addr relay received sent connected time addr processed addr rate limited ping minping feefilter
85 174.138.24.121:58174 /Satoshi:24.0.1/ spy inbound ipv4 v1 true false 0.0 MB 0.9 MB 5535s 0 234 232 -
1215 [2400:6180:0:d0::108d:2001]:47746 /Satoshi:24.0.1/ spy inbound ipv6 v1 true false 0.0 MB 0.8 MB 5175s 0 238 235 -
1249 24.144.98.209:42578 /Satoshi:24.0.1/ spy inbound ipv4 v1 true false 0.0 MB 0.7 MB 4695s 0 77 77 -
1269 [2604:a880:400:d0::e6a:6001]:58234 /Satoshi:24.0.1/ spy inbound ipv6 v1 true false 0.0 MB 0.7 MB 4335s 0 79 79 -
1290 [2a00:1398:4:2a03::bc11]:59856 /dsn.kastel.kit.edu/bitcoin:28.0.0/ spy inbound ipv6 v2 true true 0.0 MB 0.7 MB 4002s 0 4427 195 -
1295 [2001:67c:1220:808:f6:d81b:74a:ae60]:49694 /bitcoinj:0.16.2/Bitcoin Wallet:9.26/ spy inbound ipv6 v1 true true 0.0 MB 0.6 MB 3923s 0 5289 173 -
1310 [2001:41b8:810:40:f8d9:8dff:fed6:866d]:56736 /dsn.tm.kit.edu/bitcoin:0.9.99/ spy inbound ipv6 v1 true true 0.0 MB 0.6 MB 3831s 1 166 156 -
1311 [2a00:1398:4:2a03:4e52:62ff:fe22:6c13]:41658 /dsn.tm.kit.edu/bitcoin:0.9.99/ spy inbound ipv6 v1 true true 0.0 MB 0.6 MB 3831s 0 169 160 -
1328 [2001:67c:1220:808:d5:a28:cc2:27c5]:57934 /bitcoinj:0.16.2/Bitcoin Wallet:9.26/ spy inbound ipv6 v1 true true 0.0 MB 0.6 MB 3689s 0 11048 164 -
1464 [2a01:4f8:222:291f::2]:44763 /bitnodes.io:0.3/ spy inbound ipv6 v1 true false 0.0 MB 0.4 MB 2198s 0 157 157 -
1567 23.88.18.119:34518 /:1.0.0-deve79d9922c/ spy inbound ipv4 v1 true true 0.0 MB 0.2 MB 1252s 0 163 163 -
1604 46.101.92.98:35868 /Satoshi:24.0.1/ spy inbound ipv4 v1 true false 0.0 MB 0.1 MB 886s 0 144 144 -
1642 [2604:d500:4:1::4]:48775 /bitcoinj:0.14.4/Bitcoin Wallet:5.20/ spy inbound ipv6 v1 true true 0.0 MB 0.1 MB 467s 1 122 122 -
1643 [2604:d500:4:1::3:34]:11386 /Satoshi:0.15.0.1/ spy inbound ipv6 v1 true true 0.0 MB 0.1 MB 467s 1 126 126 -
1644 [2604:d500:4:1::3:63]:23275 /bitcoinj:0.14.4/Bitcoin:1.075/ spy inbound ipv6 v1 true true 0.0 MB 0.1 MB 467s 1 124 124 -
1658 209.222.252.41:44223 /Satoshi:0.15.0/Knots:20170914/ spy inbound ipv4 v1 true true 0.0 MB 0.0 MB 348s 1 133 133 -
1659 162.218.65.145:30475 /Satoshi:0.14.2(BIP148)/Knots:20170618/ spy inbound ipv4 v1 true true 0.0 MB 0.0 MB 348s 1 138 138 -
1660 91.198.115.55:22385 /Satoshi:0.10.0/ spy inbound ipv4 v1 true true 0.0 MB 0.0 MB 348s 1 147 147 -
1669 [2a03:b0c0:1:d0::f1b:c001]:40408 /Satoshi:24.0.1/ spy inbound ipv6 v1 true false 0.0 MB 0.0 MB 276s 0 150 150 -
1678 [2604:d500:4:1::4]:36126 /Satoshi:0.19.1/ spy inbound ipv6 v1 true true 0.0 MB 0.1 MB 224s 0 321 321 -
1680 91.198.115.114:31742 /Satoshi:0.13.1/ spy inbound ipv4 v1 true true 0.0 MB 0.1 MB 209s 0 257 257 -
1694 209.222.252.80:46991 /bitcoinj:0.14.4/Bitcoin Wallet:5.25/ spy inbound ipv4 v1 true false 0.0 MB 0.0 MB 66s 0 177 177 -
1695 209.222.252.238:62468 /Satoshi:0.10.1/ spy inbound ipv4 v1 true false 0.0 MB 0.0 MB 66s 0 185 185 -
1696 209.222.252.167:57642 /Satoshi:0.13.1/ spy inbound ipv4 v1 true false 0.0 MB 0.0 MB 66s 0 186 186 -
1697 [2604:d500:4:1::4]:49039 /Bitcoin ABC:0.15.0(EB8.0)/ spy inbound ipv6 v1 true false 0.0 MB 0.0 MB 54s 0 164 164 -
1698 [2604:d500:4:1::4]:9440 /Bitcoin ABC:0.14.6(EB8.0)/ spy inbound ipv6 v1 true false 0.0 MB 0.0 MB 54s 0 174 174 -
I think it’s also that genuine nodes are very non-aggressive in making connections – it takes a while for your address to propagate, takes a while for it to be tried, and you’ll only get a long lasting connection when the node restarts or if you get lucky via the extra blocks only or extra outbound logic.
I just noticed the same on a freshly node I set up. I thought very weird to have many connections from these kind of user agents.
