OS fingerprints of ~16.6k Bitcoin nodes
I scanned publicly reachable Bitcoin nodes with nmap -O and aggregated the detected operating system as Linux, Windows, BSD, macOS, Other/Device, or Unknown.
Latest scan (2026-07-07): 16,662 IPv4/IPv6 targets
  • Reachable: 10,625 (63.8%)
  • Unreachable: 6,037 (36.2%)
OS classification among reachable hosts (n = 10,625):
  • Linux: 6,653 (62.6%)
  • Unknown: 2,852 (26.8%)
  • Windows: 453 (4.3%)
  • Other/Device: 370 (3.5%)
  • BSD: 194 (1.8%)
  • macOS: 95 (0.9%)
  • Other: 6 (0.1%)
  • Solaris: 2 (0%)
Repository with the CSVs, scripts, caveats and full methodology. I plan to monthly scan and update this repo with new data:
Thanks for posting!
In Implement more extractors · Issue #141 · peer-observer/peer-observer · GitHub , I had a brief look at the Windows IPs. I thought many of these were probably hosted at Azure, but it turns out, many of them are actually on an ISP, not hosted. Here’s a quick and dirty overview.
Feel free to continue posting the monthly updates here too.
I had a look at my peer-observer node IPs in this data:
  • Most of them are correctly identified as Linux
  • Two of them are marked as Unknown. I think these have a stricter firewall on the hoster side
  • One of them is marked as Other/Device, but it also sits behind a stricter firewall
If someone is running a node on Windows, it would be interesting to look it up in the CSV and report if it’s correctly identified.
I had another look at OS Fingerprinting of Bitcoin Nodes. Happy to see that you’ve been updating it!
For Linux, the numbers seem relatively stable, with a slight increase (which might be variance). About 7800-7900 IPv4 and IPv6 Linux nodes. I wonder how many of these are listening on both IPv4 and IPv6 and are counted here twice. Maybe @danielabrozzoni can help with data from Fingerprinting nodes via addr requests - Protocol Design - Delving Bitcoin.
Similar for Windows. Somewhere around 500 nodes responded on IPv4 and IPv6.
Unknown, Other/Device, and Other have been rising.
Around 100 nodes are running on MacOS:
Somewhere around 150-200 nodes on BSD:
And around 100 are identified as Android:
A single one is identified as Solaris.
