Update: The original title of this observation was “Proxy Servers spun up in mid November 2026”. I initially assumed these were spies, but as @andrewtoth pointed out, they are actually exploiting CVE-2026-117601 in Electrum Wallet. I changed the title to better reflect what’s actually discussed here on 2026-11-25T19:05:00Z. The original post follows:
While working on an Electrum server monitoring tool for Research and exploration: Can we spot public spy-Electrum servers run by Chainalysis? · Issue #11 · 0xB10C/project-ideas · GitHub, I came across a bunch of new domains that were registered and gossiped as Electrum servers in the past week. Based on the server.banner and server.donation_address, they seem to be acting as a proxy for well-known Electrum servers (e.g. @Emzy’s electrum.emzy.de and fulcrum.sethforprivacy.com).
I suspect (but don’t know and can’t prove) they might try to become someone’s main connection which you’d sent your past and future addresses too. Since they sit between you and a real Electrum server, they learn about your addresses. This might be interesting for something like a chain-analysis company for address clustering.
Here are a few of the ones I’ve seen grouped by registrar, but there’s more weird activity going on.
Registered with NameSilo
| Domain | IP address | Hoster | Registered |
| electron-node.pro | 208.85.21.100 | Vultr | 2026-11-16 |
| fulcrumbtc.asia | 149.248.16.78 | Vultr | 2026-11-16 |
| bitcoindpubnode.pw | 45.32.146.93 | Vultr | 2026-11-16 |
| prunebtcnode.top | 149.28.82.120 | Vultr | 2026-11-17 |
| solidusnode.cfd | 104.238.134.88 | Vultr | 2026-11-17 |
| chainlinkbtc.sbs | 155.138.174.59 | Vultr | 2026-11-18 |
| utxo-relay.cc | 103.43.75.56 | Vultr AU | 2026-11-18 |
| satoshi-relay.top | 45.76.46.237 | Vultr | 2026-11-18 |
| ledgerbitcoin.site | 216.128.129.247 | Vultr | 2026-11-18 |
Registered with PublicDomainRegistry
| chainwatch.info | 45.32.253.162 | Vultr | 2026-11-18 |
| hodlnode.pro | 5.104.72.149 | MHost NL | 2026-11-19 |
| genesisblock.beer | 213.193.244.16 | PsychoVPS NL | 2026-11-19 |
| 21million.surf | 213.193.244.15 | PsychoVPS NL | 2026-11-19 |
| block840000.xyz | 45.95.99.92 | MHost NL | 2026-11-19 |
| ironledger.biz | 45.95.99.94 | MHost NL | 2026-11-19 |
| stackingsats.biz | 103.227.84.94 | MHost DE | 2026-11-19 |
| tickfreedom.wiki | 200.96.111.3 | MHost PL | 2026-11-19 |
| btc-node01.club | 173.199.93.87 | Vultr | 2026-11-18 |
| blockkeeper.wiki | 66.42.62.79 | Vultr SG | 2026-11-18 |
Registered with NameCheap
| el-commu.cc | 159.198.44.166 | Namecheap | 2026-11-15 |
| qbtcnode.network | 104.207.85.201 | Namecheap | 2026-11-16 |
| block-stream.info | 209.74.95.244 | Namecheap | 2026-11-16 |
| fulcrumhub.cloud | 203.161.43.200 | Namecheap | 2026-11-18 |
| lightbtc .co | 104.207.85.33 | Namecheap | 2026-11-17 |
| fulcrumx.online | 203.161.58.171 | Namecheap | 2026-11-15 |
I checked the Electrum self-signed TLS certificate (on port 50002) for some of these:
DOMAIN:PORT IP EXPIRES
el-commu.cc:50002 159.198.44.166 Nov 13 17:29:11 2036 GMT
qbtcnode.network:50002 104.207.85.201 Nov 13 17:49:19 2036 GMT
fulcrumx.online:50002 203.161.58.171 Nov 13 17:49:22 2036 GMT
block-stream.info:50002 209.74.95.244 Nov 14 17:25:31 2036 GMT
electron-node.pro:50002 208.85.21.100 Nov 14 18:19:36 2036 GMT
bitcoindpubnode.pw:50002 45.32.146.93 Nov 14 18:19:36 2036 GMT
fulcrumbtc.asia:50002 149.248.16.78 Nov 14 18:19:38 2036 GMT
chainlinkbtc.sbs:50002 155.138.174.59 Nov 15 20:56:04 2036 GMT
ledgerbitcoin.site:50002 216.128.129.247 Nov 15 20:56:05 2036 GMT
fulcrumhub.cloud:50002 203.161.43.200 Nov 15 20:56:11 2036 GMT
solidusnode.cfd:50002 104.238.134.88 Nov 15 21:12:58 2036 GMT
prunebtcnode.top:50002 149.28.82.120 Nov 15 21:12:59 2036 GMT
lightbtc.co:50002 104.207.85.33 Nov 15 21:13:05 2036 GMT
genesisblock.beer:50002 213.193.244.16 Nov 16 13:37:30 2036 GMT
21million.surf:50002 213.193.244.15 Nov 16 13:38:07 2036 GMT
hodlnode.pro:50002 5.104.72.149 Nov 16 13:38:27 2036 GMT
utxo-relay.cc:50002 103.43.75.56 Nov 16 13:38:30 2036 GMT
satoshi-relay.top:50002 45.76.46.237 Nov 16 13:47:21 2036 GMT
btc-node01.club:50002 173.199.93.87 Nov 16 13:47:21 2036 GMT
blockkeeper.wiki:50002 66.42.62.79 Nov 16 13:47:22 2036 GMT
chainwatch.info:50002 45.32.253.162 Nov 16 13:47:23 2036 GMT
block840000.xyz:50002 45.95.99.92 Nov 16 15:58:18 2036 GMT
ironledger.biz:50002 45.95.99.94 Nov 16 15:58:18 2036 GMT
tickfreedom.wiki:50002 200.96.111.3 Nov 16 15:58:18 2036 GMT
stackingsats.biz:50002 103.227.84.94 Nov 16 16:03:38 2036 GMT
Here’s an example certificate from block-stream.info (this is not blockstream.info!).
$ openssl s_client -connect block-stream.info:50002 -servername block-stream.info -showcerts </dev/null
Connecting to 209.74.95.244
CONNECTED(00000003)
depth=0 CN=block-stream.info
verify error:num=18:self-signed certificate
verify return:1
verify return:1
Certificate chain
0 s:CN=block-stream.info
i:CN=block-stream.info
a:PKEY: RSA, 2048 (bit); sigalg: sha256WithRSAEncryption
v:NotBefore: Nov 17 17:25:31 2026 GMT; NotAfter: Nov 14 17:25:31 2036 GMT
-----BEGIN CERTIFICATE-----
MIIDWzCCAkOgAwIBAgIUMZd95j7duTRjj7DW7wfqyQ30shcwDQYJKoZIhvcNAQEL
BQAwHDEaMBgGA1UEAwwRYmxvY2stc3RyZWFtLmluZm8wHhcNMjYxMTE3MTcyNTMx
WhcNMzYxMTE0MTcyNTMxWjAcMRowGAYDVQQDDBFibG9jay1zdHJlYW0uaW5mbzCC
ASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAJZtc9xGXp2f4db2beZdg6lA
xvZI1BWX13aN1V7T6UHhYMSTA94oB5V2WgKLTSev9/ouZF4oBALXqa2/CM0NBWO3
pS1EJhC2JDQEIvlvV51VhFC8BQYsldbu3eUGWw/6nNVjNlmi1YddgaznWanqofLH
XA/2iGiWkBbe8Xfjng0LSm/61NcbpxahG4zcDlKou6AFFmBmyeiskVDtgXOjHX8f
yjkeNqu8gxR5WN/FwQXQZ0hP0w/OvqKvvAZyeuJBA946U6y+dr/4eHNOLCU97rNU
lteEUIgBM7zczHGLVzM35hIuwtoPtAhePx1dE3Bq2vvpgN/w79IQ9fQlnnC6kZEC
AwEAAaOBlDCBkTAdBgNVHQ4EFgQUBr07sdRqKBVR8rLoDh6rrL9Jsz4wHwYDVR0j
BBgwFoAUBr07sdRqKBVR8rLoDh6rrL9Jsz4wDwYDVR0TAQH/BAUwAwEB/zAcBgNV
HREEFTATghFibG9jay1zdHJlYW0uaW5mbzALBgNVHQ8EBAMCBaAwEwYDVR0lBAww
CgYIKwYBBQUHAwEwDQYJKoZIhvcNAQELBQADggEBADcjLFS8p5bZrQtOOKgcuAvy
J/oAiFHvY6fJl/3F0v6gaAh8g2SM4FUxf+CQNl+VUnuAZBLKm4c4lWhnpCTBaW4w
oFjJEMoqJQVEnB7N7z2O3CRVNerUMThIOBQH5Y0OJWZX7Yy6Sepmf756c/g6tRla
FU9ncUQv27yJ+IucRngPRF56u1luo56fgZgwpJlvYGE0oBZiaGhM+YQKBrbWwzRq
Xm5+XipbXEzRk9wHaLMgWA2jANh1eSNpHehe69yfISL5Y9G8TKTibH1p602Eflx2
rir3jJPU+6I7e2dxC+pr4MjyhqYg2p5lOkTybbeK+z2AqBlLVUdnHQZLA1zyDmo=
-----END CERTIFICATE-----
Server certificate
subject=CN=block-stream.info
issuer=CN=block-stream.info
No client certificate CA names sent
Peer signing digest: SHA256
Peer signature type: rsa_pss_rsae_sha256
Peer Temp Key: X25519, 253 bits
SSL handshake has read 1423 bytes and written 1628 bytes
Verification error: self-signed certificate
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Protocol: TLSv1.3
Server public key is 2048 bit
This TLS version forbids renegotiation.
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 18 (self-signed certificate)
DONE
Will post updates here once I find out new things.
