Unreachable addresses in Bitcoin GETADDR responses
In the past few months we saw many unreachable addresses being gossipped on the p2p network (see this thread or this one). This refers to unsolicited ADDR messages, but I wondered if we could find some more information on what’s happening by looking at nodes’ GETADDR responses instead.
I am interested to see the percentage of unreachable addresses returned by each node in a GETADDR response. This could tell us two different things:
  • how much the recent address flooding may have affected the addrman tables of otherwise well-behaved nodes.
  • whether unreachable addresses are being spread only through unsolicited ADDR messages, or also through nodes’ responses to GETADDR.
(The latter is a bit harder to see… If you see a node responding only with unreachable addresses, maybe it’s trying to spam the network, or maybe it’s simply a victim of such spam!)
For now I have a lot of data and not many conclusions. I’ll be off for a few days, so I wanted to post what I have :slight_smile:
First, disclaimer: I usually use virtu’s p2p-crawler to crawl the network, but it needs python 3.9 to run, and was missing some features I needed. I ended up having Claude Opus 4.8 and GPT-5.6 rewrite most of the crawler, and I have not fully reviewed the resulting code yet. Don’t trust this data too much, it might be completely off.
The crawl run took ~8 hours, starting at 19:13 UTC on 15/07/2026 and ending at 03:12 UTC on 16/07/2026. It seems that during that time the number of unique addresses in unsolicited ADDR messages dipped significantly.
For each address observed during the crawl, I recorded one of three outcomes:
  • reachable: I connected and completed the Bitcoin handshake;
  • unreachable: the address was valid, but I could not connect to it;
  • handshake failed: I established a connection, but could not complete the Bitcoin handshake.
I reached 21,837 nodes:
Network Reachable % of all reachable
onion_v3 11,170 51.15%
ipv4 4,626 21.18%
i2p 4,254 19.48%
ipv6 1,787 8.18%
I also found 671,825 unique unreachable addresses:
Network Unreachable % of all unreachable
ipv4 432,682 64.40%
ipv6 217,373 32.36%
onion_v3 19,192 2.86%
i2p 2,578 0.38%
I also found 1,353 addresses where the connection succeeded but the handshake failed:
Network Handshake failed % of all handshake-failed
ipv4 518 38.29%
onion_v3 496 36.66%
i2p 176 13.01%
ipv6 163 12.05%
Putting everything together:
Network Reachable Unreachable Handshake failed Total % unreachable % handshake failed
i2p 4,254 2,578 176 7,008 36.8% 2.5%
ipv4 4,626 432,682 518 437,826 98.8% 0.1%
ipv6 1,787 217,373 163 219,323 99.1% 0.1%
onion_v3 11,170 19,192 496 30,858 62.2% 1.6%
I recorded the ADDR messages received after sending GETADDR to each reachable peer, and calculated the percentage of unreachable addresses in each peer response.
For this analysis, I excluded peers that returned fewer than 10 addresses, so the filtered sample contains 19,859 peers.
Percentage of unreachable addresses per getaddr response:
% unreachable Nodes % of nodes
0%–10% 0 0.00%
>10%–20% 1 0.01%
>20%–30% 1 0.01%
>30%–40% 8 0.04%
>40%–50% 389 1.96%
>50%–60% 3,998 20.13%
>60%–70% 41 0.21%
>70%–80% 932 4.69%
>80%–90% 10,481 52.78%
>90%–100% 4,008 20.18%
Percentage of handshake-failed addresses per getaddr response:
% handshake failed Nodes % of nodes
0%–10% 19,859 100.00%
>10%–20% 0 0.00%
>20%–30% 0 0.00%
>30%–40% 0 0.00%
>40%–50% 0 0.00%
>50%–60% 0 0.00%
>60%–70% 0 0.00%
>70%–80% 0 0.00%
>80%–90% 0 0.00%
>90%–100% 0 0.00%
This is… interesting. First of all, the majority of the spam is composed of addresses we can’t even reach, not addresses we can reach but can’t complete the handshake (I was expecting this, but wanted to double check).
And, more interestingly, the percentage of unreachable addresses in the nodes responses is alarmingly high! More than 70% of the peers in the filtered sample return >80% of unreachable addresses in their responses.
We can double check this by looking at some nodes addrmans. I looked at peer.observer’s nodes + two of my own nodes (fusillo and spaghetto[1]), and calculated the % of unreachable addresses in the new/tried table.
Snapshot New entries New unreachable New unreachable rate Tried entries Tried unreachable Tried unreachable rate
alice 65,520 63,663 97.17% 10,007 4,538 45.35%
bob 65,514 63,349 96.70% 8,359 3,882 46.44%
charlie 65,516 63,645 97.14% 10,035 4,548 45.32%
dave 65,526 57,465 87.70% 12,560 4,605 36.66%
erin 65,512 57,517 87.80% 12,810 4,704 36.72%
frank 65,513 63,442 96.84% 8,384 3,858 46.02%
greg 65,522 63,381 96.73% 7,884 3,791 48.08%
ian 65,523 63,632 97.11% 11,988 4,681 39.05%
jade 65,516 57,387 87.59% 13,799 4,770 34.57%
kane 55,576 25,727 46.29% 10,740 3,236 30.13%
luke 65,515 63,465 96.87% 11,288 4,599 40.74%
mike 65,205 63,227 96.97% 11,049 4,631 41.91%
nico 65,530 62,961 96.08% 9,119 4,426 48.54%
owen 65,515 63,648 97.15% 7,897 3,930 49.77%
paul 65,507 63,589 97.07% 2,950 1,669 56.58%
fusillo 65,520 58,868 89.85% 12,059 4,616 38.28%
spaghetto 65,461 58,058 88.69% 12,810 4,715 36.81%
It appears that the new tables are full of unreachable addresses. To try and put these numbers in perspective:
  • it’s normal to have unreachable addresses in our addrman - nodes come and go all the time!
  • To promote an address to the tried table, we must have successfully connected to it at least once. This means that fake addresses that have never corresponded to a reachable node cannot enter the tried table. Currently, roughly 30% to 50% of the addresses in the tried table are unreachable.
Meaning, 90% of unreachable in the new table is likely higher than usual, but not catastrophic.
(It would be great if we could have some historic data on this!)
Lastly, I wondered: can we get some additional information by looking at the node versions in each percentage bucket? Which versions seem more affected?
I have not looked too deeply into this yet, so I have not found many particularly interesting patterns. Here is a dump of the data I have. I included every user agent with at least 50 responses across buckets, and grouped every family that wasn’t Core or Knots into an Other category.
For each user agent, I am showing the number of responses, its share of the bucket, and how common it is overall, to see whether any version is overrepresented in a particular percentage bucket.
A bunch of data >10%–20% unreachable, 1 response:
Client family Responses Share of bucket Overall share Representation ratio
Core:29.1.0 1 100.0% 2.2% 45.97x
20–30% unreachable, 1 response:
Core:29.0.0 1 100.0% 3.9% 25.62x
30–40% unreachable, 8 responses:
Knots:20260508 2 25.0% 16.5% 1.52x
Core:29.3.0 1 12.5% 9.1% 1.38x
Core:29.2.0 1 12.5% 5.3% 2.36x
Knots:20260210 1 12.5% 4.8% 2.60x
Core:30.2.0 1 12.5% 4.7% 2.67x
Core:27.0.0 1 12.5% 3.9% 3.21x
Core:31.1.0 1 12.5% 1.5% 8.27x
40–50% unreachable, 389 responses:
Core:26.0.0 231 59.4% 4.5% 13.22x
Core:29.0.0 39 10.0% 3.9% 2.57x
Core:29.2.0 30 7.7% 5.3% 1.45x
Knots:20260508 18 4.6% 16.5% 0.28x
Core:29.3.0 14 3.6% 9.1% 0.40x
Core:27.1.0 14 3.6% 2.7% 1.32x
Core:28.1.0 6 1.5% 5.9% 0.26x
Core:31.0.0 5 1.3% 19.0% 0.07x
Knots:20260210 4 1.0% 4.8% 0.21x
Knots:20251110 4 1.0% 2.0% 0.51x
Core:27.2.0 4 1.0% 0.6% 1.69x
Core:30.2.0 3 0.8% 4.7% 0.16x
Core:28.0.0 3 0.8% 2.0% 0.39x
Knots:20250305 3 0.8% 1.3% 0.59x
Core:30.0.0 2 0.5% 3.0% 0.17x
Core:24.0.1 2 0.5% 0.6% 0.81x
Core:31.1.0 1 0.3% 1.5% 0.17x
Core:25.0.0 1 0.3% 1.2% 0.21x
Knots:20250903 1 0.3% 1.0% 0.27x
Knots:20260507 1 0.3% 0.8% 0.33x
Knots:20251010 1 0.3% 0.6% 0.41x
50–60% unreachable, 3,998 responses:
Knots:20260508 560 14.0% 16.5% 0.85x
Core:26.0.0 468 11.7% 4.5% 2.61x
Core:31.0.0 430 10.8% 19.0% 0.57x
Core:29.3.0 369 9.2% 9.1% 1.02x
Core:29.0.0 359 9.0% 3.9% 2.30x
Core:29.2.0 356 8.9% 5.3% 1.68x
Knots:20260210 184 4.6% 4.8% 0.96x
Core:30.2.0 172 4.3% 4.7% 0.92x
Core:27.1.0 164 4.1% 2.7% 1.50x
Core:28.1.0 148 3.7% 5.9% 0.62x
Core:25.0.0 95 2.4% 1.2% 1.92x
Core:29.1.0 89 2.2% 2.2% 1.02x
Core:28.0.0 78 2.0% 2.0% 0.98x
Core:30.0.0 75 1.9% 3.0% 0.62x
Core:27.0.0 65 1.6% 3.9% 0.42x
Knots:20251110 63 1.6% 2.0% 0.78x
Core:31.1.0 58 1.5% 1.5% 0.96x
Core:27.2.0 53 1.3% 0.6% 2.18x
Core:24.0.1 40 1.0% 0.6% 1.58x
Knots:20250305 36 0.9% 1.3% 0.69x
Knots:20250903 28 0.7% 1.0% 0.74x
Knots:20251010 29 0.7% 0.6% 1.16x
Knots:20260507 20 0.5% 0.8% 0.65x
Core:25.1.0 8 0.2% 0.4% 0.49x
60–70% unreachable, 41 responses:
Knots:20260508 13 31.7% 16.5% 1.92x
Core:31.0.0 9 22.0% 19.0% 1.15x
Core:27.0.0 6 14.6% 3.9% 3.75x
Core:29.3.0 4 9.8% 9.1% 1.07x
Core:26.0.0 4 9.8% 4.5% 2.17x
Core:29.2.0 2 4.9% 5.3% 0.92x
Knots:20260210 1 2.4% 4.8% 0.51x
Core:27.2.0 1 2.4% 0.6% 4.00x
70–80% unreachable, 932 responses:
Core:27.0.0 357 38.3% 3.9% 9.83x
Knots:20260508 250 26.8% 16.5% 1.63x
Core:31.0.0 178 19.1% 19.0% 1.00x
Core:29.2.0 25 2.7% 5.3% 0.51x
Core:30.2.0 24 2.6% 4.7% 0.55x
Core:30.0.0 21 2.3% 3.0% 0.74x
Knots:20260210 12 1.3% 4.8% 0.27x
Core:29.1.0 8 0.9% 2.2% 0.39x
Core:28.1.0 7 0.8% 5.9% 0.13x
Core:28.0.0 6 0.6% 2.0% 0.32x
Knots:20251110 6 0.6% 2.0% 0.32x
Knots:20260507 6 0.6% 0.8% 0.84x
Core:29.3.0 5 0.5% 9.1% 0.06x
Knots:20251010 5 0.5% 0.6% 0.86x
Core:29.0.0 4 0.4% 3.9% 0.11x
Knots:20250305 3 0.3% 1.3% 0.24x
Core:26.0.0 2 0.2% 4.5% 0.05x
Core:31.1.0 1 0.1% 1.5% 0.07x
Knots:20250903 2 0.2% 1.0% 0.23x
Core:27.2.0 2 0.2% 0.6% 0.35x
Other 2 0.2% 0.2% 1.25x
Core:27.1.0 1 0.1% 2.7% 0.04x
Core:25.0.0 1 0.1% 1.2% 0.09x
80–90% unreachable, 10,481 responses:
Core:31.0.0 2,404 22.9% 19.0% 1.21x
Knots:20260508 2,002 19.1% 16.5% 1.16x
Core:29.3.0 1,273 12.1% 9.1% 1.34x
Knots:20260210 635 6.1% 4.8% 1.26x
Core:29.2.0 583 5.6% 5.3% 1.05x
Core:28.1.0 502 4.8% 5.9% 0.81x
Core:30.2.0 420 4.0% 4.7% 0.86x
Core:30.0.0 357 3.4% 3.0% 1.12x
Core:27.1.0 286 2.7% 2.7% 1.00x
Knots:20251110 245 2.3% 2.0% 1.16x
Core:29.1.0 231 2.2% 2.2% 1.01x
Core:29.0.0 223 2.1% 3.9% 0.55x
Core:28.0.0 206 2.0% 2.0% 0.99x
Knots:20250305 180 1.7% 1.3% 1.31x
Core:27.0.0 155 1.5% 3.9% 0.38x
Knots:20250903 128 1.2% 1.0% 1.28x
Core:26.0.0 101 1.0% 4.5% 0.21x
Core:31.1.0 98 0.9% 1.5% 0.62x
Knots:20260507 96 0.9% 0.8% 1.19x
Knots:20251010 78 0.7% 0.6% 1.19x
Core:25.0.0 61 0.6% 1.2% 0.47x
Core:27.2.0 46 0.4% 0.6% 0.72x
Core:24.0.1 28 0.3% 0.6% 0.42x
Core:25.1.0 11 0.1% 0.4% 0.26x
Other 10 0.1% 0.2% 0.56x
90–100% unreachable, 4,008 responses:
Core:31.0.0 753 18.8% 19.0% 0.99x
Core:28.1.0 516 12.9% 5.9% 2.17x
Knots:20260508 432 10.8% 16.5% 0.65x
Core:30.2.0 310 7.7% 4.7% 1.65x
Core:27.0.0 190 4.7% 3.9% 1.22x
Core:29.0.0 149 3.7% 3.9% 0.95x
Core:30.0.0 147 3.7% 3.0% 1.21x
Core:29.3.0 139 3.5% 9.1% 0.38x
Core:31.1.0 141 3.5% 1.5% 2.33x
Knots:20260210 118 2.9% 4.8% 0.61x
Core:29.1.0 103 2.6% 2.2% 1.18x
Core:28.0.0 101 2.5% 2.0% 1.27x
Core:25.0.0 88 2.2% 1.2% 1.77x
Core:26.0.0 86 2.1% 4.5% 0.48x
Knots:20251110 82 2.0% 2.0% 1.02x
Core:27.1.0 77 1.9% 2.7% 0.70x
Core:25.1.0 62 1.5% 0.4% 3.79x
Core:29.2.0 56 1.4% 5.3% 0.26x
Core:24.0.1 56 1.4% 0.6% 2.20x
Knots:20250305 39 1.0% 1.3% 0.74x
Knots:20250903 30 0.7% 1.0% 0.79x
Knots:20260507 30 0.7% 0.8% 0.97x
Other 22 0.5% 0.2% 3.21x
Core:27.2.0 15 0.4% 0.6% 0.61x
Knots:20251010 11 0.3% 0.6% 0.44x
I noticed that the “Other” category is overrepresented in the >90-100% bucket. Here’s the raw data with IPs hidden, since it’s only 22 responses:
Node Percentage of unreachable Network Version Services User agent
1 90.90% IPv4 70016 NODE_BLOOM, NODE_WITNESS, NODE_NETWORK_LIMITED /btcwire:0.5.0/btcd:0.25.0/
2 91.80% IPv4 70016 NODE_BLOOM, NODE_WITNESS, NODE_NETWORK_LIMITED /btcwire:0.5.0/btcd:0.25.0/
3 90.80% IPv4 70016 NODE_BLOOM, NODE_WITNESS, NODE_NETWORK_LIMITED /btcwire:0.5.0/btcd:0.25.0/
4 93.91% IPv4 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2 /CKCoinD:31.0.0/
5 91.90% IPv6 70016 NODE_NETWORK, NODE_BLOOM, NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2, bit12 (0x1000), bit13 (0x2000) /btcwire:0.5.0/utreexod:0.5.1/
6 94.40% IPv6 70016 NODE_BLOOM, NODE_WITNESS, NODE_NETWORK_LIMITED /btcwire:0.5.0/btcd:0.25.0/
7 95.30% IPv4 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2, bit12 (0x1000) /Ghost:1.10.22/
8 94.41% IPv6 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2 /CKCoinD:31.0.0/
9 95.40% IPv6 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2, bit12 (0x1000) /Ghost:1.10.22/
10 94.20% IPv6 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2, bit12 (0x1000) /Ghost:1.10.22/
11 93.80% IPv6 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2, bit12 (0x1000) /Ghost:1.10.22/
12 96.40% IPv6 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2, bit12 (0x1000) /Ghost:1.10.22/
13 96.40% IPv6 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2, bit12 (0x1000) /Ghost:1.10.22/
14 97.20% IPv6 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2, bit12 (0x1000) /Ghost:1.10.22/
15 91.80% IPv4 70016 NODE_NETWORK, NODE_BLOOM, NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2, bit12 (0x1000), bit13 (0x2000) /btcwire:0.5.0/utreexod:0.5.1/
16 94.21% IPv4 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2 /CKCoinD:31.0.0/
17 96.70% IPv4 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2, bit12 (0x1000) /Ghost:1.10.22/
18 95.80% IPv4 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2 /CKCoinD:31.0.0/
19 94.61% IPv4 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2 /CKCoinD:31.0.0/
20 95.90% IPv4 70016 NODE_NETWORK, NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2 /Satoshi-Noderunners:31.0.0/
21 94.81% IPv4 70012 NODE_NETWORK, NODE_BLOOM, NODE_XTHIN /Classic:1.2.0(EB3.7)/
22 95.70% IPv4 70016 NODE_WITNESS, NODE_NETWORK_LIMITED, NODE_P2P_V2, bit12 (0x1000) /Ghost:1.10.22/
And that’s it! I would love it if someone tried to reproduce all of this - I’m not very confident in the data I found, and I’m sure a few bugs slipped in somewhere :slight_smile:
  1. Yes, I named my nodes after Italian pasta. I am very pleased with myself. ↩︎
This might be some of the historic data you were asking about:
b10c archives daily getrawaddrman snapshots of the two demo.peer.observer nodes (hal and len) in bitcoin-data/getrawaddrman, going back to 2026-02-02 (gap: Feb 15 to Mar 3, hal until Mar 11).
I don’t have access to the production nodes from your table, so I worked with what’s public.
I replayed the git history and computed the metrics below from the snapshots alone. The snapshots contain no connection outcomes, so none of this is a reachability measurement.
new table (hal/len) pre-flood (Feb to early Apr) during flood (May to mid-Jul) after the Jul 15 drop
size 65.3-65.5k, already full 65.5k, full 65.5k, full
entries with gossip timestamp 7d 71-76% mostly 95-97%[1] falling, 72-78% on Jul 19
daily endpoint turnover 1-1.5%/day 0.3-0.5%/day[2] 0.4-0.5%/day
Since the tables were already full in February, the flood shows up in composition, not size. The 7d timestamp share climbed from late April and crossed 95% in early May.
The same signal shows up in the getrawaddrman export deadmanoz shared on the BNOC datashare (four nodes, daily snapshots 2026-03-05 to 2026-06-10). The two VPS nodes follow the same curve: 71% baseline, above 97% by mid-May. The two home nodes, which are not reachable for inbound clearnet connections, started from a lower baseline (47-50%, they see less gossip overall) and peaked at 75%. So the flood clearly reached them through their outbound peers too, but with visibly less intensity than nodes accepting inbound. Those series end in May/June though.
What I find most interesting: turnover fell to a third of pre-flood levels and has stayed there after Jul 15. Of the new entries present on Jun 1, 81-83% are still there today. Of the Jul 14 set, 97.7% (hal only, len has no snapshots Jul 14-17). The flood population just sits there, so GETADDR pollution lags the injection I think.
If the injection really stopped around Jul 15, addrman’s 30-day horizon makes a testable prediction: these entries become “IsTerrible” as their timestamps age, and GETADDR responses filter terrible entries, so the pollution you measured should decline substantially by roughly mid-August. The slots themselves only get freed when a colliding address overwrites a terrible entry, a restart doesn’t purge them either, so the tables will look polluted much longer I guess. If GETADDR pollution does not recede on that timescale, something is still refreshing the timestamps.
As a separate present-day cross-check (not a join against the addrman data):
I’ve been archiving DNS seed responses and full seeds.txt crawler dumps since early July in bitcoin-seeder-data. In the Jul 19 dumps, 91% of fish.foo’s and 94% of achow101’s tracked endpoints have never completed a version handshake from their vantage points (both run dnsseedrs, which drops never-successful entries after >10 failed tries, so this is a rolling window, not a lifetime count).
But applying your unreachable-endpoint classification to the full Feb-Jul history would be much stronger than my seeder cross-check.
Hope this helps!
  1. brief dips below 95% in late June; the deeper one (len, 80%) follows a snapshot gap and looks like node downtime. ↩︎
  2. excluding two restart-like events (May 29, Jul 1) where both nodes lost and refilled 1-3k slots within days. ↩︎
Thanks for posting! I think this addr-spam is interesting, but I didn’t get a chance to look closer into it while it happened. I should have data from the connectivity-check peer-observer tool (“A peer-observer tool that checks the connectivity of received addr(v2) message entries by connecting to the addresses and trying to do a version handshake. The results are recorded in a CSV file.”). If someone is interested in diving deeper, I’m happy to share this. This should give us an overview over:
  • how many IPs were gossiped in addr messages over time?
  • how many of then were unreachable?
  • which are unreachable ones that appeared only after the addr-spam started?
  • are there any specific IP or timing patterns?
Happy to share that data, just reach out! Not going to post it publicly just yet as it contains IPs.
Just a quick update on the same two demo.peer.observer addrmans (hal / len).
new table
(hal / len)
pre-flood during flood 19 Jul 22 Jul – 5 Aug 15 Aug
7d timestamp 71–76% 95–97% 78.4% / 72.4% 42–46% 83.1% / 81.7%
daily turnover 1–1.5% 0.3–0.5% 0.4–0.5% 0.4–0.5% 4.2% / 4.4%
The thing I wanted to check from 19 July was addrman’s 30-day horizon. After 15 July the 7-day share fell to 42–46% for a couple of weeks. The July bulge aged out of that window, but the same endpoints stayed in the table, so turnover stayed low. Then both lines jump in mid-August. Freshness going back up looks like a new flood, but the turnover spike is the 30-day recovery. Those July addresses can finally be overwritten.
During the flood, freshness was high and turnover was low: same addresses getting new timestamps. This time turnover peaked around 12%/day on 13–14 August, and the rows that left hal almost all had gossip timestamps from 12–14 July. That is 30 days later, which is addrman’s horizon, and it lines up with the freeze timed around 14 July in #164. The replacements are current gossip, so the 7-day share goes through the old 71–76% range and is 83.1% / 81.7% on 15 August.
I’d expect this to settle back toward the old range soon. If it doesn’t, I’ll post another update. A good new discussion of what this did to the network is in Address Relay under stress.
